SailNet Community - View Single Post - long distance cruising in a PS 34?
post #18 of Old 09-04-2018
roverhi
roverhi's Avatar
Re: long distance cruising in a PS 34?
75 gallons of water and 38 gallons of fuel is not small. Smaller boat, smaller diesel, lower fuel fuel consumption. The engine stated in Sailboat Data is 38hp which is way overpowered to my thinking. Have a 27hp Yanmar in my same size boat and it's more than adequate. Hopefully lower rpm will equate to lower fuel consumption even with too big engine.
We had identical water capacity in two tanks. Caught water from the awning and never had to switch to 2nd between rainfalls filling the tanks back up in French Polynesia. Yes you can be profligate with water but disconnecting the pressure water pump and only using foot pumps is an instant no pain conservation technique. If you can't get by on the fuel and water capacity of a PSC 34 you really should consider a floating condo permanently attached to a dock with water and electric.
roverhi is online now
