SailNet Community - View Single Post - Is the boat yard screwing you? stories
post #16 of Old 09-08-2018
travlin-easy
travlin-easy's Avatar
Re: Is the boat yard screwing you? stories
It is entirely possible that the original strut was made of fiberglass. I recently discovered that my cutlass bearing housing was made completely of fiberglass and that's the way they came from the factory. Also found several powerboats with fiberglass struts, so apparently, it's not a rare thing. Might want to check with the manufacturer or their spec sheets to find out if this is the case.
Good luck,
Gary
travlin-easy is offline
