SailNet Community - View Single Post - Thru hull possibly leaking... what to do
post #5 of Old 09-11-2018
overbored
overbored's Avatar
Re: Thru hull possibly leaking... what to do
look like someone put in bigger drains then it came with. those drains are just above the waterline. you could loosen the big white retainer nut and put a bead of sealer around the thur hull threads and retighten the nut. if it works then you will be good for another 30 years. if not then you will need to remove and rebid from both sides. looks to me like they did not use sealer and are relying on the epoxy only. do not use silicon seal or 5200. I would use 3m 4200 sealer as it is removable at a latter date
"GOLD RUSH" PRINDLE 16
overbored is online now
