SailNet Community - View Single Post - teak decks - how much work are they really?
post #19 of Old 09-15-2018
Jeff_H
Administrator
Jeff_H's Avatar
Re: teak decks - how much work are they really?
Originally Posted by sailforlife View Post
Teak deck has lots of holes that leak eventually...
I believe that the original poster was asking about Hallberg Rassey which uses a glue down system which doesn't require a lot of holes. The issue with that system as it was explained to me is that they only use 10 mm planks. That works okay in a Northern climate where boats are out of service part of the year, in normal use real teak erodes between 1/16 and 3/32 per decade and so I would be concerned about having enough depth to allow the seam caulk to remain properly adhered.
Jeff_H is online now
