SailNet Community - View Single Post - Simpson Lawrence gypsy not matching chain
post #22 of Old 09-28-2018
capta
Master Mariner
capta's Avatar
Re: Simpson Lawrence gypsy not matching chain
Originally Posted by MarinaOnMaui View Post
Good point. Upon closer inspection of the chain there were also links in it that connected different chain, so it's possible the original piece was BBB and then they added G4. Who knows. It's a mess. The only problem with changing to 5/16 is I'm not sure if it's strong enough fo the boat which is 21,000 lbs and a 45lb Bruce.
No chain you can fit aboard your boat is going to be strong enough to hold your boat (21,000#) if it is straight from the anchor to the boat, not even our ˝" BBB! You must set yourself up with a nylon snub line for elasticity in the setup. Personally, I'd always go with the heaviest chain your gypsy can handle, not the more expensive smaller size G-4.
In 1971 I had my 3/8" BBB chain break in Hanalei Bay, Kauai when the wind swung north and the boat began pitching in the rising seas. I immediately thereafter set up a snub line and have always used one when anchoring since and have never broken my chain again.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
The Following User Says Thank You to capta For This Useful Post:
MarinaOnMaui (09-28-2018)
