SailNet Community - View Single Post - Crazy first time out on my sailboat today
post #23 of Old 11-04-2018
Minnewaska
Re: Crazy first time out on my sailboat today
Originally Posted by TimMarks View Post
......I am wondering what the two holes are that the water is draining from in the first pictures you posted of the boat sitting on the trailer.
As I understand the OP, these were the cockpit scuppers. Is that right?
This would mean that water completely filled the cabin, came up on the cockpit floor and only the cockpit drained out.
That seems odd, not to mention extreme.
Do these scuppers have hoses that lead from the cockpit to the hull? Some do, some are molded in. Looks like the outlet is below the water line, so it too is suspect to have actually caused the leak.
A 1" hole that is 2ft below the surface will flow at the rate of 28 gallons per minute. Obviously, the OP's leak was much smaller or shallower, as they would have never been out for the half hour they describe, with any easily noticeable hole.
Jeanneau 54DS
Minnewaska is offline
