SailNet Community - View Single Post - Crazy first time out on my sailboat today
post #42 of Old 11-05-2018
TakeFive
TakeFive's Avatar
Re: Crazy first time out on my sailboat today
As Minne hinted, a properly done plug is going to take much longer than a properly done in-kind repair/replacement. Those through-hulls are there for good reason. The scuppers are essential to safety (and required by ABYC standards). Water will get in your cockpit, even with a cover. And when the boat is in use, there are many ways that rainwater or seawater will get into the cockpit. It needs to drain out, or your boat will become dangerously out of balance. Having shifting ballast is dangerous - it always shifts to the low point of the boat, which is the opposite side from where you want it.
Plugging your sink drain is similarly shortsighted. You'll need that sink for a lot more than washing hands. Suppose you do need to get into the bilge with Chlorox bottles or hand pumps to address a leak. Where is that water going to go? Are you really going to walk each cup of water out into the cockpit and throw it over the gunwale? You'll never keep up that way. You would put it in the sink.
There is a lot of useful knowledge here. Take advantage of it. Many of us have different styles and levels of bluntness. If you have a know-it-all attitude, some here will throw that right back at you. After contributing here for 10-15-20 years, people sometimes get that way. That may not be the most effective, but it's human nature. That doesn't mean their points aren't right.
I think you need to start listening more to the advice here. I'm not going to rant too much, but I do think taking that baby on an untested (and overloaded) boat was one of the dumbest things I've ever heard. Right as soon as I started reading your first post, when I got to that part I was screaming, "Noooooo!!!!!"
PS - You must add a bilge pump.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
