SailNet Community - View Single Post - Crazy first time out on my sailboat today
post #43 of Old 11-05-2018
SeaStar58
Re: Crazy first time out on my sailboat today
My 15 foot picnic boat has a sink/ice chest which drains thru-hull below the water line which keeps the melting ice from sloshing around and spilling out into the cockpit or bilge and is a very good design point even on a boat without a cabin and as others mentioned it can be a life saver on a boat with a cabin allowing you to bail or use a hand pump to purge water directly into it and out of the boat.
Scuppers below the water line with a proper venturie cap can greatly speed draining water out of the cockpit and get your boat more quickly back in balance after it takes a wave, etc. And electric bilge pump only works if the battery is still functional which may not be the case if its foaming over from getting salt water in it while the scuppers will work constantly and at times better than many bilge pumps especially if you have any forward motion plus they will keep working even if you are incapacitated.
Serious consideration should be given before defeating the safety features built into a boat. The root cause of this incident is more likely poor maintenance and prep and not poor design. That boat is a very well proven design with thousands out of the water.
SeaStar58 is offline
The Following User Says Thank You to SeaStar58 For This Useful Post:
MikePNJ (11-05-2018)
