SailNet Community - View Single Post - Electric Conversion log for Kahleesea
post #53 of Old 01-05-2019 Thread Starter
Captain Canuck
Re: Electric Conversion log for Kahleesea
Sean,
Electricity is like the sea. If you give it a chance, it will kill you. I'm pretty careful with my wiring, having learned it from a friend of mine who's been a professional electrician for over 30 years. He's helped me reno three of my homes. I've also had to go through the OSHA safety training course a couple time for various contracts I've worked on. I don't consider myself an expert, but I am extraordinarily cautious around electricity and am a firm believer in "too much safety is just enough". I will be testing the hell out of the system I build long before it gets on my boat. If anything is going to melt down, I'd rather it do so on my concrete workshop floor rather than inside my boat.
I think I'm not explaining myself well. Thrust dictates speed. Once the water resistance matches the thrust from the prop, acceleration stops and the speed remains steady. Whether that thrust comes at 800 RPM or 1200 RPM is probably irrelevant. I guess I'll find out. I can't put Khaleesea on the hard until some space frees up, so I don't even know how big my prop is right now. Probably 16x10 or thereabouts. Hopefully I'll be up on the hard soon so I can take measurements.
Point taken about overdriving the motor temporarily. The DC cables on Kahleesea are already 2/0. From what I've read, at 48V that's over 200A, more than enough for cruising speed. Since DC and AC systems converge in the starboard aft compartment, that's where I'll put all electric connections. Looks like the charger and the inverter are going to have to be separate, since I can't find an inverter/charger unit that works with lithium batteries.
Are you putting your genset where your old diesel was? I can't imagine there are too many places in a 29' boat where you can put something like that. I'd also be interested to see your wiring diagram if you have one.
I find it interesting that you're going with the Chevy Volt model of hybrid propulsion. If I needed a longer cruising range, that would be the direction I would go too, but with as much solar as I could cram overhead.
Captain Canuck is offline
