SailNet Community - View Single Post - Electric Conversion log for Kahleesea
post #94 of Old 01-11-2019
mbianka
Re: Electric Conversion log for Kahleesea
Originally Posted by texlan View Post
I haven't reviewed your installation in a while but I believe you are running 4 12v batteries in series. Each 12v battery consists of 6 2v nominal cells that when charged are a touch over 2.1v.
Likelyhood is that one cell has had crumbling lead antimony plates that may or may not have shorted together in the bottom of the battery, resulting in low charge capacity or effectively no capacity.
The other cells (not just in the one battery but in the entire string) are driving current through the bad cell. When the bad cell's limited capacity is exhausted, the rest of the battery will drive the cell into reverse (Think of it as charging the cell backwards. at 46 volts). This further damages the plates in the cell, causes electrolysis and offgassing and generates heat. The cell, instead of being a producer in the circuit, has now become a consumer/resistor. Further more, once the cell is in full short, when you charge your whole bank you wind up OVER charging the rest of the cells to make up the bad cell's lack. You're in a better position than most LA/SLA users with individual battery voltage monitoring, Mike, so at least you can catch this.
Will it catch on fire and burn your boat down? EHHhhhh... depends on the exact nature (impedance of the short), the current being driven through it and time, probably not in the very short term. But at the high currents used in electric propulsion it would scare the crap out of me. <-- disclaimer, BS is going to say that i'm giving you bad advice and am trying to kill you with that statement. I'm just saying what you saw; you were able to continue under gen assisted motoring and get back to harbor without a fire. But I'd be as uncomfortable with the situation as you clearly are so, all good.
Sean
Thanks for explaining in the detail of what may be happening. The boat is on land for the winter back on Long Island and I'm in the Maldives on an eight day charter. Briefly currently there is no load on the battery bank . My 48 volt solar panels are keeping things charged and I usually head to the boat every few weeks and use the Dual Pro 4 charger as you mentioned to charge the batteries up. Since they charge each individual battery in the string I'm not to concerned about over charging the bank.. But, the suspect battery will be replaced in the spring once things warm up. Ironically the suspect battery charges up the same as the others but, it's capacity is short lived as your analysis appears spot on.
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is offline
