SailNet Community - View Single Post - Outboard for Cruising
post #1 of Old 01-18-2019 Thread Starter
Boxerz123
I've decided to bring back a Alberg 30 to life from the depts of despair. I plan on doing extensive cruising but sadly money is tight so I'm looking to find a project boat and work on it over the next 2 years. The boats in this range have either no engine or the engine needs replacement. So I'm thinking of converting the lazarette into an outboard well and removing the old Atomic 4 engine. Assuming all goes well what does everyone think of cruising with an outboard?
I'll be going with a long-shaft 9.9 hp Nissan or something similar with a reserve tankage of 4 x 3 galon cans. I know I won't be getting the same range as an inboard diesel but given the shoe string budget and wanting to keep the engine as simple as possible is this a viable solution for long-term voyaging?
My thinking is that with good routing/planning I'd keep motoring to a minimum and sail most of the time whenever I can. And money and space for the existing engine can be used for better purposes.
Cheers
Boxerz123 is offline
