SailNet Community - View Single Post - Outboard for Cruising
post #7 of Old 01-18-2019
Sailormon6
Re: Outboard for Cruising
Ten hp should be adequate. I know of a Triton that does well with an 8 hp, and it's only about 600 lbs less than the Alberg 30.
After the A4 is removed there will be plenty of space to install a 12 gal tank, or even larger. It has to be installed to meet ABYC specs. They don't appear too cumbersome. By the time you buy 4 tanks and the necessary fittings, you could probably buy a permanently installed 12 gal tank for not much more.
You can get some guidance at this link. https://www.westmarine.com/WestAdvis...tion-Checklist
Sailormon6 is online now
The Following User Says Thank You to Sailormon6 For This Useful Post:
Boxerz123 (01-18-2019)
