SailNet Community - View Single Post - Black water holding tank
post #1 of Old 01-30-2019 Thread Starter
Teamstone
Teamstone's Avatar
35 Allmand
Holding tank under the dinette (assume that in the normally place for it)
I have a small leak (confirmed by dye)
Not sure if it is the screw in "blank" on the stern side of tank or a small crack in the bottom.
Will be trying to remove the blank on the left and using Boatlife to seal it. I have attached a photo of the plug I am talking about.
Assuming that doesn't work, will be needing to R&R it.
Do we know who made the tank and if it still available?
I assume I will have to cut out the fiberglass under the dinette seat to do the R&R and than have it repaired.
If you have to have a custom tank made, who do you recommend?
Teamstone is offline
