SailNet Community - View Single Post - Amount of lead in fin keel of 1969 C&C 36 ft sailboat
post #9 of Old 01-31-2019
Jeff_H
Administrator
Jeff_H's Avatar
Re: Amount of lead in fin keel of 1969 C&C 36 ft sailboat
Originally Posted by DickyBob View Post
Does anyone know how I can find out how much lead (approx) is in the keel of a 36 ft C&C sailboat built in 1969. My sailboat needs to be disposed of and I'm hoping I can recoup some of my expenses by selling the lead. It is has a fin keel and I've been told there is less lead in it than a fixed keel. Is there anywhere online I can go online to get this kind of information?
C&C (the boat builder) did not build a 36 footer in 1969. C&C the designers had three designs in production that were between 34 and 36 feet: Invader (3,000 lbs lead ballast), Redwing 35/C&C 35-1 (5000 lbs lead ballast), and the Frigate (5200 lbs lead ballast but part of that was in the centerboard).
For the record, a fin keel is fixed keel. If this is a centerboard boat, (i.e. what you may be thinking is the fin keel is able to be moved) then it is likely that there will be a higher ballast weight, but some of that weight will be in the keel and some in the centerboard.
Jeff_H is online now
The Following User Says Thank You to Jeff_H For This Useful Post:
DickyBob (02-01-2019)
