SailNet Community - View Single Post - Amount of lead in fin keel of 1969 C&C 36 ft sailboat
post #20 of Old 02-12-2019
Minnewaska
Re: Amount of lead in fin keel of 1969 C&C 36 ft sailboat
Originally Posted by SanderO View Post
dunno about the different coefficient of elasticity... but neither will keep that joint water proof if the boat is sailed upwind in heavy seas.
Where did you get the notion it would?
Itís not a notion, itís been field tested for years. As you noted, the movement is slight. The elasticity of 4200 is fully sufficient to take it up. I check the joint each Fall and itís never failed. On an iron keel, rust at the joint is a tell tale, even if it doesnít get all the way into the bolts. I replace the 4200 every few years.
Jeanneau 54DS
Minnewaska is offline
