SailNet Community - View Single Post - Barrier Coat vs. Bottom Paint Application
post #4 of Old 02-12-2019
celenoglu
celenoglu's Avatar
Re: Barrier Coat vs. Bottom Paint Application
If you plan barrier coating, make sure the hull is dry, the humidity should ideally be less than 10%. Higher humidity (above 14%) might cause osmosis if barrier coat is applied. The hull will not dry on the hard unless the gel coat is removed.
celenoglu is online now
