SailNet Community - View Single Post - Barrier Coat vs. Bottom Paint Application
post #6 of Old 02-13-2019
Don0190
bell ringer
Don0190's Avatar
Re: Barrier Coat vs. Bottom Paint Application
Originally Posted by celenoglu View Post
If you plan barrier coating, make sure the hull is dry, the humidity should ideally be less than 10%. Higher humidity (above 14%) might cause osmosis if barrier coat is applied. The hull will not dry on the hard unless the gel coat is removed.
Where does one a place with such low humidity
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is offline
