SailNet Community - View Single Post - Electric Conversion log for Kahleesea
post #167 of Old 02-22-2019
mbianka
Re: Electric Conversion log for Kahleesea
Originally Posted by boatsurgeon View Post
To each their own.
How do you charge batteries connected in series separately?
For any vessel with an electric propulsion system, I recommend separate isolated systems for propulsion and 12 Vdc for safety equipment, with their own charging sources, double, triple, or quadruple redundancy for the safety.
As mentioned, a bad side effect of that set-up is if you have a propulsion system electrical failure, or a DC-DC converter failure, ya got nuthin' for safety equipment and lighting, till you can tear it apart and re-wire.
Not pleasant if getting beat-up, which is when stuff like this normally happens.
(One shouldn't have a low voltage problem if the electrical system design is properly balanced and maintained.)
I agree. When I converted to EP I kept my house 12 volt bank and kept it separate from my Electric Propulsion bank. I saw no reason to get rid of the working 12 volt house bank and just down convert from 48 volts. I'm a if it ain't broke don't fix it kind of guy. I also don't like to have all the eggs in one basket. I'm glad I did it this way. Last summer I had issue with a breaker in the EP system. I had to disconnect the 48 volt bank for a few days while I figured it out. Never had to worry about the house bank since it was separate and kept working as usual including refrigeration.
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is offline
