SailNet Community - View Single Post - Cal 21 Owners
Thread: Cal 21 Owners
post #125 of Old 03-08-2019
Seana
Re: Cal 21 Owners
Also, looking at your pic its very clear to see the center piece of plywood is contiguous. In the corner where it crosses the bulkhead are each of these plywood cut with a slot? Are the side bulkheads seperate pieces ( they look a different grain) . Details of the original joinery in this area would be VERY helpful especially as strength is through the design. Lots of epoxy needed over the new wood. I'm considering encapsulating it in fiberglass so this never has to be done again.
The only advantage you have over me is having the original to use as a pattern. You're actually going to have to do just as much work as almost all of your wood is going to need to be ripped out to get to the point I am at now.
Seana is offline
