SailNet Community - View Single Post - Thru Hull Modification
post #7 of Old 04-19-2019
roverhi
roverhi's Avatar
Re: Thru Hull Modification
Since those are tapered flush mount through hulls, the only real fix is to laminate up layers of glass till it's flush, fair and than redrill and countersink for the new through hull. I had a similar problem only the new through hull was not a flush mount and had a large enough diameter that it overlapped the counter sunk part enough to just fill the void with caulking.
If the old through hull is bronze could you reuse it with the new seacock??
roverhi is online now
