0
Re: Just purchased a 1973 Pearson 30, need advice.
I have 3 questions for you now that I am back on board.
Do you remember/know what bottom paint was used when you did it? Thi is helpful so I can use a compatible paint.
What is the fuel tank capacity and did you clean the tank when you did the engine swap?
Was the port aft quarter damaged when you had her? Maybe this happened after - some very shoddy repair work has been done and I am trying to figure out how bad the damage under the repair was.
I actually sailed Luft Tanz last Wednesday in light airs. She did well despite a totally wrong mainsail.
Look forward to getting back in touch with you - Thanks
