SailNet Community - View Single Post - Alternator for Volvo MD2030
post #13 of Old 04-26-2019
colemj
colemj's Avatar
Re: Alternator for Volvo MD2030
Originally Posted by jarcher View Post
Thanks everyone, I really appreciate the help. I went to the boat today and snapped a pic to show you but it looks just like the ones posted. The yellow wire is clearly available externally. How does this work? The same screw with the yellow wire on it is connected to the battery + terminal so I presume this is where the power comes out. What does the voltage sense do?
Thanks again.
The voltage sense wire senses the voltage of the battery. In the Valeo alternator, it is assumed that the battery voltage on the positive terminal represents the real voltage of the battery. This is rarely true. You can simply unclip it from the alternator post and lead it straight to your battery for better accuracy.
Alternately (or in addition), you can put a diode in-line with it and use its voltage drop to trick the alternator into providing higher voltage and more current than it would normally while charging.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
