SailNet Community - View Single Post - Is tinned boat wire necessary?
post #19 of Old 04-30-2019
colemj
colemj's Avatar
Re: Is tinned boat wire necessary?
Originally Posted by celenoglu View Post
The cover of wire is osmotic. If you pass the wire from the bilge, water will osmotically pass to the wire and cause crevice corrosion. It is best to use tinned wire.
I'm pretty sure this is not true. At least not on less than glacial time scales. Likely, any issue with water will be one of wicking from a penetration, and not osmosis. Could you point to a reference regarding this? If osmosis and crevice corrosion is a concern with marine wire, tinned wire won't prevent it.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
