SailNet Community - View Single Post - Is tinned boat wire necessary?
post #34 of Old 04-30-2019
Captain Canuck
Re: Is tinned boat wire necessary?
Originally Posted by boatpoker View Post
How are you checking that with a multi-meter ?
If you are checking resistance by ohms, one intact strand can show 0.0ohms.
My Multi has a clamp. I ran power through the 00 cable to see if it was still good after the continuity test. The input amperage matched what the multi was telling me right up to the cut-off of 180A, so I assume the cable is still good.
Now that I think about it, I should have done a temperature test at the same time to make sure the cable wasn't heating up under load. I'll check that when I finish wiring the batteries into the boat.
Captain Canuck is online now
