SailNet Community - View Single Post - Repowering- What to do with Old Engine?
post #8 of Old 05-05-2019
davidpm
davidpm's Avatar
Re: Repowering- What to do with Old Engine?
Originally Posted by olson34 View Post
Experienced wrench turners can likely guess what those are......)
What else did that 10K include if you don't mind mentioning?
Transmission
shaft
prop
fuel tank
control panel
shifter and throttle
Remove old engine
Prep engine bed
Did you do a lot of the work yourself?
OK spill what happened to the other engine brand install, and what brand was it?
davidpm is online now
