SailNet Community - View Single Post - Polyurethane foam insulation
post #16 of Old 05-08-2019
Scandium
Re: Polyurethane foam insulation
Originally Posted by Pasadena View Post
Thank you very much Scandium, It's a great idea to contact the manufacturing company. I think that regardless of is safety, I should try to remove as much as I can from all the accessible areas. It is not all over the boat and the most difficult area would be the V Berth, which has no wiring through as far as I can tell, except maybe for the pilot lights in front. I need to check that.
If you do remove some put a lighter, or blowtorch, to it and see how well it burns If it really is non-combustible under normal circumstances maybe you'll want to keep it. If it bursts into flame with thick black smoke maybe not..
Scandium is online now
