SailNet Community - View Single Post - Painting Deck and Cockpit....DIY or Pay?
post #2 of Old 05-19-2019
Minnewaska
Re: Painting Deck and Cockpit....DIY or Pay?
If the gelcoat isn't cracking, I would first try a restoration. Wet sanding, with ultra fine grit, followed by a series of progressively stepped down compounding. You could even just try compound right out of the gate to see if it gets results you're happy with.
Painting is an option, but I consider it a last choice. Once painted, always painted. The paint is not as tough as the gelcoat and will scratch, leaving you with needing to repaint down the road. If you change the color, scratch will be all the more noticeable. Then again, you'll have a different base primer color anyway, I suppose.
The only paints I would consider are either Awlgrip or Alexseal, which would benefit from a professional, with a paint gun. Alexseal is more repairable. You could do all the sanding and filling, if you wanted.
Jeanneau 54DS
Minnewaska is offline
