SailNet Community - View Single Post - Boiling Batteries
post #10 of Old 06-17-2019
john61ct
Re: Boiling Batteries
Ammeters with higher current range capacity will often have poor accuracy in the low ranges.
Unless you need to accommodate measuring very high amp loads, expensive gear capable of capturing high startup transients,
you can save money by just covering the highest rates you ever plan to charge at.
For a tiny bank like that you want decent accuracy below 1A for setting the charge termination endpoint
john61ct is online now
