SailNet Community - View Single Post - Depression and thermostats
post #3 of Old 06-29-2019
capta
Master Mariner
capta's Avatar
Re: Depression and thermostats
Gauges are notoriously inaccurate. Most offen the best they can do is let you know that the temp (in this case) is straying off the norm.
But from your description, if it is not a connection in the wiring, it could be a faulty thermostat. Not much else, and I lean toward a wiring connection if the temp changes are as rapid as you imply.
I'd get a heat gun and make sure the engine is or is not actually changing temperature at all, and change the thermostat just because.
Good luck.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
