SailNet Community - View Single Post - Depression and thermostats
post #6 of Old 06-29-2019
colemj
colemj's Avatar
Re: Depression and thermostats
Does the water flow out change at all when this is happening? If not a bad sender/gauge, it sounds like something is rolling around in the cooling loop plugging/unplugging flow. Could be a thermostat opening/shutting, but that is an odd failure mode. Just remove the thermostat and see what it does. Some engines block the flow when the Tstat is removed, but these are usually fresh water cooled engines - but check to make sure.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
