SailNet Community - View Single Post - GROCO K-type marine head question
post #2 of Old 07-14-2019
SanderO
SanderO's Avatar
Re: GROCO K-type marine head question
Originally Posted by kbbarton View Post
I've noticed that the bowl always seems to fill 1/3 - 1/2 full of water on its own, despite my pumping the bowl dry each time it is used. Over time, minerals have precipitated out onto the bowl and it just looks, well, unattractive. There is no smell to the water. I keep the water intake valve to the toilet closed, and the bowl still seems to collect water. At 1/3 - 1/2 full, it's okay... but if it gets higher than that, I don't want any spilling out if the boat is heeled over! Is there a valve somewhere that might have a worn/cracked seal that is letting water into the bowl? If it was back-up from the holding tank, I would expect it to smell bad. Any ideas?
No it doesn't. Your seals are not working. I did a complete rebuild and once pumped out it is completely dry.
For water to enter the choker valve or the flapper valve below the bowl are not working.
pay attention... someone's life depends on it
SanderO is online now
The Following User Says Thank You to SanderO For This Useful Post:
kbbarton (07-18-2019)
