SailNet Community - View Single Post - 40 yr old teak decks
post #6 of Old 07-20-2019
Yorksailor
Yorksailor's Avatar
Re: 40 yr old teak decks
In 15 years of cruising, I have seen several boats with old, failing teak decks and I have seen the disasters that can lurk beneath the teak due to 20-30 years of leaks:
Rotted deck cores, plywood or balsa,
Chainplates that crumble because of crevice corrosion,
Internal bulkheads, that support chainplates, rotted out.
Keeping a mast vertical when a chainplate goes and you are out in a storm can be challenging.
Usually, there is a reason that a boat is priced well below market!
Good luck, you might need it! The only way to know is to go and see!
Yorksailor is offline
