SailNet Community - View Single Post - Diesel Fuel Treatment: Multiple Questions
post #3 of Old 09-29-2019
pdqaltair
pdqaltair's Avatar
Re: Diesel Fuel Treatment: Multiple Questions
What you need for corrosion is an additive that inhibits corrosion. In fact, that has been studied. Biobor won't help.
https://www.practical-sailor.com/iss...s_11083-1.html But really, nearly all water comes in through the deck fill or vent (really--samples nearly always show salt), and the salt is what makes it aggressive. Just a tiny bit.
Regarding dead microbes, if a biocide is used as a preventative, the number will be so small your filters will easily handle it. If you waited until they were clogging the system, no additive can dissolve that much, and would it be a good thing if it could (they will be going through your injectors)? Face it, you need to clean such a tank.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
