SailNet Community - View Single Post - Diesel Fuel Treatment: Multiple Questions
post #23 of Old 10-01-2019
pdqaltair
pdqaltair's Avatar
Re: Diesel Fuel Treatment: Multiple Questions
Originally Posted by JoeDunn View Post
If it helps, my Yanmar JH series operation manual, under Additional Technical Fuel Requirements, states, "Do not use biocide".
It is an interesting statement. Several thoughts:
* Biobor, to my understanding, is used in most jet fuel. That's a rather critical use.
* Not all biocides are the same. Some (not Biobor JF) will crystallize and fall out if not mixed well. It seems odd to paint them all with one brush.
* If you use a biocide AFTER you have an infection, you will get dead bugs and clogging, and some of that will be on the other side of the filter, where it can damamge injectors.
You MUST use a biocide as a preventative, not as a treatment for existing disease.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
