SailNet Community - View Single Post - stiff steering
Thread: stiff steering
post #35 of Old 10-02-2019
DaveMancini
DaveMancini's Avatar
Re: stiff steering
The waterproof grease needs to be added when the boat is out of the water, preferably on a warm day (although heat can be added with a torch) so that the grease works its way in to the mating surfaces between the rudder post and the gudgeon. I always did this whenever I hauled out: lots of grease and lots of working the rudder back and forth. If you add it when the boat is in the water (diving down), the grease will just float to the surface inside the shaft (waterline).
Dave
DaveMancini is online now
