SailNet Community - View Single Post - Compac 16' Keel advice needed
post #9 of Old 11-16-2019
Minnewaska
Re: Compac 16' Keel advice needed
Interesting job. Are you going to remove the bilge to access the ballast or go through the encapsulation from the outside. The bilge would leave an intact encapsulation to refill, but then you need to structurally replace the bilge. The encapsulation probably needs to be reinforced, but more curious is how you insure a good bond to the encapsulation, when you refill.
The lead will change the weight of the ballast, but I doubt that will make sailing her all that different. If significant, it may alter her waterline though. Is your plan to imbed the ingot into an epoxy slurry of some kind? Insuring this slurry bonds to the existing glass?
Jeanneau 54DS
Minnewaska is offline
