SailNet Community - View Single Post - Compac 16' Keel advice needed
post #10 of Old 11-16-2019
Arcb
Moderator
Arcb's Avatar
Re: Compac 16' Keel advice needed
Cool idea with the lead. It should sit lower in the keel and make the boat stiffer. It will be less dense so you will have some void space to fill. You might want to consider the weight of the filler too. Those compac 16s are already pretty heavy boats, so I wouldn't want to over do it.
Arcb is offline
