SailNet Community - View Single Post - Help figuring out this engine buzzer circuit
post #8 of Old 11-17-2019
BobT
Re: Help figuring out this engine buzzer circuit
My guess is that this is the answer:
You said the buzzer is grounded through a wire connected to the engine block. If you look closer at the connection point on the engine block, you should find it to be an oil-pressure switch connecting the ground side of the buzzer only when there is little or no oil pressure. When there is sufficient oil pressure, the connection at the oil-pressure switch will be disconnected from ground and the buzzer will stop.
BobT
San Diego
Thinking about looking for a sailboat
BobT is online now
