SailNet Community - View Single Post - Universal M-12 in the shop: Offseason proactive attention??
post #5 of Old 11-23-2019
eherlihy
Learning the HARD way...
eherlihy's Avatar
If I could remove my M25, I would: set the valve clearance, pop test injectors, check injector timing, preform a compression and leak down test, and because the engine is canted aft, I would change the oil pan drain to the rear of the sump in the oil pan. Then clean up any rust, wash down with carb. cleaner and apply a fresh coat of the $40 Universal Bronze paint.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is offline
