SailNet Community - View Single Post - Universal M-12 in the shop: Offseason proactive attention??
post #6 of Old 11-24-2019
captflood
captflood's Avatar
Re: Universal M-12 in the shop: Offseason proactive attention??
GREETINGS EARTHLINGS : While the engine is out replace all the fuel lines doing away with as many joints as possible , remove all the rubber as well clamping as you go keep a flexible area from bulkhead to engine replace the return pipe as well when you can and paint the engine room white cause it will show up all the leaks and spills as soon as it starts now is a fine time to update to led lights in the engine room and make access to the areas for filters and pumps if you need to do you need to add any extra bit to the engine now is the time to do it AS ALWAYS GO SAFE
captflood is offline
