SailNet Community - View Single Post - Universale m -18 RPM won't go over 2000
post #12 of Old 12-10-2019
PhilCarlson
PhilCarlson's Avatar
Dock
Re: Universale m -18 RPM won't go over 2000
Originally Posted by sailing11 View Post
Exhaust elbow is next up. In order to do this, I have to disconnect the raw water hose that's on the exhaust riser. This hose is going straight to the anti-syphon valve. Do I need to worry about water coming in when I take this hose off the exhaust riser?
Only if it's below the water line. You could plug the inlet or add aa temporary extention to raise it above the water line while you work on the engine.
PhilCarlson is online now
