SailNet Community - View Single Post - Charging outboard battery onboard
post #5 of Old 12-14-2019
john61ct
Re: Charging outboard battery onboard
If you are happy with the **voltage** level of the charge sources, the another way to limit the current is with an Echo-Charge, in this case to 15A.
https://www.sailnet.com/forums/elect...g-feature.html
The EC will drop the source voltage by ~0.4V but in this case that's likely a good thing, I use about 13.8V for 4S LFP. The maximum cap is 14.4V.
john61ct is online now
