SailNet Community - View Single Post - Nissan/Tohatsu M3.5A (3 hp) removing Prop problem
post #4 of Old 01-09-2020
danvon
Re: Nissan/Tohatsu M3.5A (3 hp) removing Prop problem
If your motor is like mine, the prop would not screw on the shaft but would just press on over the shear pin. I wonder if your shear pin is broken on this one too and just enough is left sticking out to hold the prop? Have you tried prying between the prop and the impeller housing on the motor (big flat bar or screwdriver?)
danvon is offline
