SailNet Community - View Single Post - Polishing fuel filter change procedure
post #10 of Old 02-22-2020
RobGallagher
HANUMAN
RobGallagher's Avatar
Re: Polishing fuel filter change procedure
I sometimes had to use the bleed screw at the top of the filter, sometimes not (2GM). Sometimes it would run just fine, a couple of times it ran rough for a bit... Towards the end I just always bled it from that screw. Always have the crush washers on hand if you don't want things to weep.
WINDHOVER
1999 CATALINA 36 MKII
NOANK, CT
RobGallagher is offline
