SailNet Community - View Single Post - Carb Problem?
Thread: Carb Problem?
post #2 of Old 09-17-2014
kd3pc
kd3pc's Avatar
Re: Carb Problem?
burning rich, very rich. Float not set properly and idle/mixture not set properly. Don't waste your time on a compression check.
Be VERY careful with "the boat smells like gas" as vapors/fumes can cause problems.
Get it fixed, properly or do it yourself. At this point you would be better off ordering a new carb and replacing it yourself, than to give this person more money to "repair" what he has already broken. No more money for him, till it idles smoothly. He is not a mechanic.
While you may have a valve or piston problem, that is secondary to the carb getting repaired.
kd3pc is online now
The Following User Says Thank You to kd3pc For This Useful Post:
FirstCandC (09-17-2014)
