SailNet Community - View Single Post - Carb Problem?
Thread: Carb Problem?
post #4 of Old 09-17-2014
hellosailor
Re: Carb Problem?
Rebuilding a carb is more like watchmaking than general mechanic work. And even carb shops seem to screw them up more often than not. A whole new carb can be expensive, but if you can get a "major overhaul kit" for the carb, that's often ~$100 and with a gallon of gumout and an afternoon of patience you can put it back in new condition.
The overhaul kit usually includes detailed instructions, Some drill bits of wire gauges and a small steel ruler to make adjustments precisely are required, nothing exotic. Some needles or fine brushes to clean out the passages, all easily procured. The hardest part is just being patient and methodical. Take the phone off the hook, use some boxes or bags so the small parts can't run away, and take pix with a cell phone or digicam if there's any doubt about how a stack of things go together.
When it is done, if everything is rosy again, you keelhaul the alleged mechanic.
hellosailor is offline
