SailNet Community - View Single Post - Carb Problem?
Thread: Carb Problem?
post #9 of Old 09-19-2014
Marknid
Re: Carb Problem?
Blue smoke indicates oil. Running fast is idle adjustment or vacuum leak. A float set extremely low can cause fast idle but not smoke too. I would also suggest, from your description, you have other issues. Is the base gasket on correctly, vacuum connections, breather?
Marknid is offline
