SailNet Community - View Single Post - Divider in the chain locker on a PSC 34
post #8 of Old 03-25-2015
nateinmaine
Re: Divider in the chain locker on a PSC 34
Our anchor locker has two different seperators.. A very robust fiberglassed to the hull short segment and an easy to remove plywood part. I removed the plywood in the photo, you can see it lying down on the starboard side of the locker. I needed to climb in there to remove and rebed the bow pulpit and windlass.. There is a drainage area from what I can determine.. Fair amount of chain locker flotsam blocking the way presently and I believe there is some mesh that is doing its best from letting the flotsam cause trouble...I'll get the shop vac in there soon..
Nate, Athenry psc34 #89
nateinmaine is offline
