SailNet Community - View Single Post - Transmission and throttle levers both move at the same time
post #5 of Old 06-14-2015
fryewe
fryewe's Avatar
Re: Transmission and throttle levers both move at the same time
This is the brake...available widely at chandleries or on line...
The bolt head compresses the throttle cable sheath to apply pressure to the cable inside...the amount of pressure dependent on the adjustment of the machine bolt. The nut locks the bolt at the desired position. Use a wrench on the bolt head when tightening the nut to avoid changing the brake pressure.
The web makes everywhere the same place. - Fred Reed, from "Fred on Everything"
fryewe is offline
