SailNet Community - View Single Post - Draft and Mooring Depth
post #2 of Old 07-29-2015
Ho Rison
Crusty Cruiser
Send a message via Skype™ to Ho Rison
Re: Draft and Mooring Depth
There's more to it than that. You need to figure out the effect of the lowest tide, both on the depth of water at your proposed mooring and the minimum depth available from your mooring to wherever you want to go in the boat. Get a copy of the local tide tables which will give you a lot of useful information you can use to work that out.
Many boats are moored in places where the tidal range prevents them being moved at low water. When the location is sheltered enough for the water to remain calm all the time, it is not unusual for moored boats to dry out without damage on sand, mud etc. Shallow moorings on sand can be less secure from wandering thieves so make sure all your gear is secure.
Good luck and fair winds.
Ho Rison is offline
